Artikel-ID : 00378190 / Senast ändrat : 13/05/2026Skriv ut
Which Sony cameras support USB PD (USB Power Delivery)?
    The following cameras support USB PD (USB Power Delivery):
    • ILCE-1, ILCE-1M2, ILCE-9M3, ILCE-7SM3, ILCE-7RM5, ILCE-7RM6, ILCE-7M4, ILCE-7M5, ILCE-7CR, ILCE-7CM2, ILCE-6700
    • ILME-FX3, ILME-FX3A, ILME-FX2, ILME-FX30
    • ZV-E1, ZV-E10M2
    • DSC-RX1RM3
    With these cameras, you can use a USB PD compatible device for fast charging.
    The compatible outputs of the devices required to charge or supply power vary depending on the combination of your camera, charger, and other devices. Check the following.
    If you are using an ILCE-7RM6, refer to the following page.
    Compatible outputs of the devices required when charging or supplying power to batteries (NP-SA100) with the camera body or a battery charger (BC-SAD1)
    If you are using an ILCE-1, ILCE-1M2, ILCE-9M3, ILCE-7SM3, ILCE-7RM5, ILCE-7M4, ILCE-7M5, ILCE-7CR, ILCE-7CM2, ILCE-6700, ILME-FX3, ILME-FX3A, ILME-FX2, ILME-FX30, ZV-E1, or ZV-E10M2, refer to the following page.
    Compatible outputs of the devices required when charging or supplying power to batteries (NP-FZ100) with the camera body or a battery charger (BC-ZD1)
    If you are using a DSC-RX1RM3, use the following commercially available USB PD compatible devices.
    • USB Type-C® cable (USB-C® – USB-C) compatible with at least 18 W
    • External power supply with an output of at least 18 W
    Related Articles
